-   -   Bravo upper gears (https://www.offshoreonly.com/forums/drives-lower-units/331290-bravo-upper-gears.html)
sac 10-01-2015 07:54 PM
Bravo upper gears
Anyone had any luck separating the upper gears from the cone clutch after a high rpm shift?
JaayTeee 10-01-2015 08:40 PM
I did on a set that was stuck in the bottom gear set....just took the keepers and the top gear off and put it in a press and pressed down on the clutch shaft...it popped and came right apart, but the shoulder on the clutch shaft where it mates with the bottom of the gear and that same area on the bottom gear were galled up and would most likely stick again, so they weren't reused.
sac 10-02-2015 11:22 AM
Thanks for the info, I have the upper gear off and in a 20 ton press with the bearing separator plate under the cone clutch and no luck so far
JaayTeee 10-02-2015 12:42 PM
What I did was put the separator plate under the raised portion of the bottom of the gear ( just to keep it off of the thrust bearing surface of the gear) and pressed on the top end of the clutch shaft.
