Trs upper With a Bravo Lower >
Old 12-10-2015 | 10:25 AM
Very cool.
ham_r_down01 is offline
Old 12-10-2015 | 10:36 AM
Yes the oil passages are machined into the adapter plate
SlowRyd is offline
Old 12-10-2015 | 11:06 AM
Slowryd. What is the dimmension from input shaft C/L to Prop shaft C/L?
abones is offline
Old 12-10-2015 | 12:14 PM
I'll have to double check that. I wasn't really concerned with that when I built it I was mostly concerned with the prop shafts in relation to the bottom of the boat
SlowRyd is offline
Old 12-10-2015 | 12:17 PM
Sure I understand, just wondering to compare with a TRS Piece I have, very interested in that distance.! Thanks
abones is offline
Old 12-10-2015 | 12:18 PM
kaama82's Avatar
Very interesting. How has it held up? What did you do with the vertical shaft?
kaama82 is offline
I can tell you it is 4.750 shorter than a stock trs
SlowRyd is offline
Old 12-10-2015 | 12:21 PM
Haven't had a chance to run it yet. I machined a stock shaft to fit and spline it to fit the trs coupler
SlowRyd is offline
Old 12-10-2015 | 01:19 PM
Curious what Gear ratio are you running?
abones is offline
Old 12-10-2015 | 02:20 PM
Xr gears ? Prop shaft ? I had same idea.
You are a genius. Bravo hand grenades are easier to get parts . Try ceramic bearings ?
KAOSS is offline
