Trs upper With a Bravo Lower >
Old 05-25-2016 | 09:30 PM
  #81
Katdrvr's Avatar
I would be interested in a pair if you could figure out the reverse rotation, have no desire to have reverse rotation engine,
Katdrvr is offline
Old 05-26-2016 | 08:19 PM
  #82
sorry
i had a total brainfart on post 80.
trs reverses rotation in the lower with gear on carrier instead of in nose.
alpha 1 gen 2 reverses rotation in lower by simply running in reverse but the carrier is shorter.
outonsafari is offline
Old 12-16-2016 | 02:09 PM
  #83
Hello SlowRyd. I pm you yesterday. I want to shorten my
Bravo lower and I wanted to talk to you about
Getting a deep enough weld. And cutting down the vertical shaft. I want to run my drive on surface. Taken out 4" to do so.
scsmike is offline
Old 12-16-2016 | 10:06 PM
  #84
Hey man I just saw this in my email. I can give you a call tomorrow to talk about it but I can tell you now 4 inches isn't possible. You don't have the space on the vertical shaft between the bearing and you prop wouldn't fit with a bravo upper. You would have to have the scx4 upper to have prop clearance.
SlowRyd is offline
Old 12-20-2016 | 01:03 PM
  #85
Biggus's Avatar
Konrad 540. Much stronger upper and very similar to the Bravo lower
Biggus is offline
Old 12-20-2016 | 03:26 PM
  #86
SlowRyd, what is the dimension you are looking for from the input shaft C/L to the prop shaft C/L?
abones is offline
Old 12-30-2016 | 05:56 PM
  #87
Hang Time 27's Avatar
Yea, that's an awesome effort, but considering I still blew a TRS upper after about 150 hours with 600hp (lowers only lasted 60-80), whereas my Konrad went 430 hours before the lower went (and I'm guessing that's cause I only changed the gear oil twice in 7 years). For me, anything over 550hp will never be in front of a bravo, TRS, or any combo of the two - just no damn fun.
Stay under that 550 or so and this is a great way to get more speed out of a TRS setup, for sure.
Hang Time 27 is offline
Old 01-17-2017 | 09:05 PM
  #88
tripps's Avatar
It sounds great ,would be alot easier than raising motor and drive on my 23 Daytona no room,,in my 4 inches below bottom,how would a 5 blade cleaver work on a stock trs? 330 Hp,soon to have more. Nice job Ryd
tripps is offline
Old 02-03-2017 | 12:34 PM
  #89
VP of the tickfaw200
ever figure out how to get it to work with twins?
caseyh is offline
Old 02-07-2017 | 04:03 PM
  #90
Only option is a cam change to reverse the engine
SlowRyd is offline
