How much hp on a xr drive
#31
#33
#34
I had Mr Gadgets put together an X drive upper with the upgrades and he went through a new "ordered from IMCO" -3 lower to make sure everything was right.
Behind 800 HP on my Daytona - second year so far without any problems. I CAN'T hole shot at all. My slip numbers at top speed are insane (4%) but I blow out getting on plane but just keep it at 5000 rpm and it gets on plane in about 7 to 10 seconds depending on prop.
#35
So why does Amsoil not recommend the severe gear for marine applications? I spoke with them and they strongly recommended but using it over their standard marine gear lube. Said the marine lube had much better ability to absorb water.
#36
Yeah, thats weird isnt it. I called them about that before too. Hate to tell them but if there is that much water in the drive we've got much worse problems! Personally, I use 110 and have added a quart of 140 the rest. Other than losing a MPH or two. It quiets and XR down and I am considering it for all the time.
#37
