Bravo 1 upper bearing install problems
So I am replacing my upper driveshaft bearings. Simple enough. Pull old bearings off. Put new bearings on. Problem is when I start to tighten down the large aluminum nut it puts too much pressure on my bearing assembly and I can't even turn the driveshaft. Loosten the nut up so its barley tight and turns free. Am I missing something? This should be very straight forward and I'm going nuts with it.
When you installed the new upper Pinion bearings did you set the rolling torque correctly and install everything in the correct order.
Everything is in order. It appears my first bearing (Closest to gear) is not sitting completely in the race. I'm going to get some pictures together.
Originally Posted by 253
(Post 4445969)
Found problem! When I opened the packages the bearings and races were packaged together so I assumed each bearing and race were a match since they were in the same box. Well long story short the races were in the right place but my bearings were swapped around. I thought it looked funny. 😒
| All times are GMT -5. The time now is 12:33 PM. |
