Broken TR prop shaft >
Old 08-01-2016 | 01:05 PM
Default Broken TR prop shaft
Cruising along when all of a sudden a bad shaking started. Turned the prop by hand and could see it was bent so I pulled the prop. Turns out the prop shaft cracked 3/4 around at the seal. Is this a common problem? I'm now looking for another prop shaft or better yet a lower unit that is ready to run.
Skipjack 28 is offline
Old 08-01-2016 | 02:00 PM
No, not common at all. Very unusual it would do that. Those are pretty much bullet proof. Sure you didn't hit something? Be easier if you just found a prop shaft. You could change it with out even removing the drive. If you just replace the lower it will need to be shimmed correctly to the upper.
There are a few on ebay. Here is the cheapest one. http://www.ebay.com/itm/MerCruiser-P...NS5V5V&vxp=mtr
Assuming you need the more common right hand rotation. Part number is 44-62792. Left hand is 44-62820. The one in the picture is a right hand but they have the left hand number on it.
picklenjim is offline
Old 08-05-2016 | 07:43 AM
I have a complete TR lower if you're looking.
6136016557
Richard
[email protected]
Rambocj7 is offline
Old 08-05-2016 | 02:24 PM
old bird's Avatar
Just curious: Is it really a TR or is it actually a TRS drive ?
and are the prop shafts interchangeable ?
old bird is offline
Old 08-06-2016 | 01:59 AM
TR and TRS prop shafts are not interchangeable.
Old 08-06-2016 | 08:38 AM
Exactly ! Not interchangeable. The reason I have a spare TR is because in thought it was a Trs. The TR has a much larger prop shaft. I find that ad on ebay deceiving because it says both. I would sell my complete lower for $350 if anyone is interested.
Rambocj7 is offline
