TRS with BW 72C 1018 Installation Dimensions
Greetings:
I'm thinking about installing a TRS drive with the BW 72C 1018 transmisson. How far from out from the transom does that setup protrude into the boat to where the bell housing bolts to the input side of the transmission? 20" - 24" ? Thanks..... |
From transom to bell housing is 15''3/4
what are you taking out? unless it is TRS-Merctrans. it is hard to justify. for that, you need about 9 to 10 inches in front of where front pulley is now.
Originally Posted by Craney
(Post 4487893)
It's hard to judge the size of objects from pictures alone. |
Originally Posted by dereknkathy
(Post 4487908)
then you need about a foot in front of the small block front pulleys.
Originally Posted by Northwester
(Post 4487918)
This is less than I initially thought.
Fortunately, I have room in the engine compartment without modifying anything forward or above for things to fit in the new location.
I can walk in front of my twins now but I will lose that privilege when I make the changes. Thanks for the info and the comments. |
| All times are GMT -5. The time now is 05:31 AM. |
