-   -   Bravo drive with 575sci (https://www.offshoreonly.com/forums/drives-lower-units/341995-bravo-drive-575sci.html)
marcusnapier 10-16-2016 10:24 AM
Question for you guys should i stay with Bravo outdrives with HD internals with Mercury 575sci? Also would nosecone or a shortie lower unit be worth it? It is a 35 Fountain lightning btw
Crude Intentions 10-18-2016 11:25 AM
Interested here. What do you run with the 575s as is?
ALL_IN! 10-18-2016 04:33 PM
The '02 Fountain Lightning I just sold had XR's with Hydromotive nose cones. I had it to 98mph. New owner pushed it to crack 100mph (GPS) last week.
575's
Mild roller cam
Small blower pulley (AZSM)
Eddie Young ECU tuning
32' Maximus props (I believe is what new owner put on it)
Fast f*n boat!
imagemaker7777 11-28-2016 02:38 PM
I just sold my 02 Lightning 35 with 575s. New cam, smaller puullys and Teague Super Chillers. Did 109mph at sea level and 98mph at 5,100 feet. XR drives with Imco lowers 30" 5 blade Maximus lab finish from BBlades
ALL_IN! 11-29-2016 07:31 AM
Did super chillers fit under the hatch?
Kelly O 11-29-2016 08:26 AM
Had an 03 35 with AZSM upgraded 575's. Added nosecones to stock XR lowers, ran Mercury labbed 32 Maximus at 103mph.
Before adding nosecones, with stock 32P Bravo props, the boat would stop accelerating but would still increase rpm's once I got into the mid 90's. Added the nosecones and 5 blade props and gained top speed as well as better cruise speed at 3500rpm.
Purchased -2 Imco lowers but never installed them as the boat got traded towards my current ride. These boats have a pretty high X dimension, I don't think the couple mph gained up top would have been worth the decrease in driveability. Never had any drive failures, did swap gears and shim drives every other year. Next owner of boat never broke a drive either, last we had talked.
CAT A BOY 02-04-2017 01:40 PM
I ran a 97 Awesome Cat with 625's with Bravo's with no issues. I wasn't out racing all the time, but from time to time I would run up over 100mph. Never hammered it hard, always eased into it.
Thewhitemongoose 02-04-2017 02:31 PM
Maximus's will run slower with the -2 IMCO lowers, they will run better with standard length drives. Bravo IX conversions are always an option, rated at 1200 HP, All American Drive in Adrian Michigan can take care of that for you.
marcusnapier 02-04-2017 09:05 PM
How difuclut was it to install the nose cones also what did you have to do with the low water pickup
JRider 02-05-2017 09:49 AM
Originally Posted by Thewhitemongoose (Post 4526011)
Maximus's will run slower with the -2 IMCO lowers, they will run better with standard length drives. Bravo IV conversions are always an option, rated at 1200 HP, All American Drive in Adrian Michigan can take care of that for you.
I don't think that is true across the board. Reducing the drag of the gear case in the water is the component that makes the boat faster, at that point a 5 blade/s can become a necessity for planing and better cruise speeds. Also, All American can label these as 1200 HP all day long, I am not drinking that coolaid.
Thewhitemongoose 02-05-2017 10:55 AM
I run 900 HP run mine with a 15.25X29P Maximus, and it runs perfectly, it just strong as an NXT #6.
JRider 02-05-2017 12:43 PM
Strong as an NXT? I find that hard to believe with NXT shafts and gears being larger. Definitely not as strong as a #6. NXT Transmission is the weak part of a NXT setup.
Thewhitemongoose 02-06-2017 03:06 AM
Mine is the XV/Bravo IX (Stage IV) built and assembled by Powequest R&D with AADS back in 2004 before XRs were available to the public, the XV Extended Drive is basically indestructed for speed and power, the transmission will hold any shift and hold any power with my whipple 525 EFI (10 PSI) and the Bravo IX is a completely 1.25" cynogenic drive with the internal frozen at over 150 degrees below zero, this will double the tinsel strength of reciprocating parts in the drive, and a Maximus is a big prop to boot. 100 MPH at 6000 RPM. X Mod*Full Tower, Mercury Steel Ribbed Top Cap, Chromoly Spanner Nut & Seal Retainer, XR Custom Gear Set, XR Custom Shower Cooler, AADS high tensile strength alloy clutch shaft, Sportmaster Custom Lower Case, and REM Polish Selected Components. Phase Four drives receive the AADS high tensile strength alloy clutch shaft and drive shaft with 1.25 prop shaft with billet carrier assembly and coupler *Critical and selected components are also Cryogenically treated and REM polished for maximum performance.
JRider 02-06-2017 08:30 AM
Looks like I should sell my teague 980s and #6s and go with a 900hp 525s with bravos, sounds like a much better package. Sounds bullet proof.
MASOMAN 02-06-2017 08:58 AM
Hey mongoose can we see some pictures of this XV/ Bravo1X set up and your 100 mph Powerquest.
Thewhitemongoose 02-06-2017 12:28 PM
https://www.facebook.com/Dr.Scott.Allan.MD, as you requested.
offshoredrillin 02-06-2017 02:34 PM
before xr's were available to the public??? WTF are you smoking, my boat is a 2000 and came with xr's stock, secondly the pic on your fb page if that is your boat is an imco on a box, with an SC lower...
Wasted Income 02-06-2017 02:42 PM
Lol, that was the first thing I noticed.
Eliminated572 02-06-2017 02:44 PM
He may want to look into a psychiatrist if he thinks any XR can hold a candle to a #6.... preferably one with a star rating above a 2....
JRider 02-06-2017 03:46 PM
Darrish
JRider 02-06-2017 03:50 PM
According to his profile he is a psychiatrist.
Thewhitemongoose 02-06-2017 04:19 PM
Call me a liar again you piece of trash and I'll hunt you down, boatless whore that fits you perfectly. All of those drive were bravo conversions hd parts in the bravo shell, the XR/HD shell as you put it didn't come out until 2006, I put all the IMCO logos on the drive because all of the parts went in the drive, the drive had no logos because it was a concept drive from MR, here it is in it's original form. https://www.facebook.com/photo.php?f...type=3&theater.
offshoredrillin 02-06-2017 04:42 PM
thats funny , because the drive you just posted is on an its box, what happened to the imco stand off box?.. please, hunt away. I look forward to it... oh btw, you be a liar :whistle:
oh and this link on mercruiser parts .com doesnt show a bravo IV..... hmmm. you funny though..
oh and oh, i almost forgot.. looking through your friends list, why does a lily white psychiatrist have 99% black friends..wtf, you the new eminem? my bs o meter is pegged on you buddy boy...
JaayTeee 02-06-2017 05:15 PM
Who makes "XR custom gear sets " ?
What's a XR/HD shell ?....slope back ?
50HUSLR 02-06-2017 05:17 PM
It looks like it's "GOING DOWN FOR REAL" is it about to be a Fight....
JRider 02-06-2017 05:25 PM
Liar
AJ POWERPLAY 02-06-2017 05:28 PM
Let's ask ourselves this... Bravos, Xrs, NXTS, #6's... who gives a f*ck if you won't even run your boat in the water your boat is meant to run! Boyne Thunder had real water, and 109 boats, a lot of them #6 and #8 boats, turned around and chose to run in 2 ft max lake waves. Don't dawg a guy about his drives when you won't run your boat in water worthy of big power drives. That's like driving a vette in a 25 MPH zone only.
JRider 02-06-2017 05:31 PM
Wow, two douchers on one thread
82predictor 02-06-2017 06:30 PM
TRS or nothing in big water!
blown 02-06-2017 07:02 PM
Originally Posted by Thewhitemongoose (Post 4526437)
Profiles dont get much faker than that.
chancer540 02-06-2017 08:54 PM
I think the guy is related to FF....:hijack::party-smiley-004:
Eliminated572 02-07-2017 07:42 AM
Get out of here Troll.... the grownup's are talking. Trashy? Irony at its best...Boatless whore? I don't brag about what I have... People with things normally don't tell the world - Take note. BOOM, BOOM! You hear that? That's mommy upstairs, lunch must be ready... Be on your way troll, and get a job - moms rent wont pay itself. :signs036:
abones 02-07-2017 07:51 AM
I'm no expert on anything specially boat stuff and spelling, but in the first picture the shinny thingy on the bottom of the drive is different then the shinny thingy on the second picture, so thus I'm confussed as usual. can someone help me out on this?
Precision 02-07-2017 08:16 AM
Scott! Is that you?!?! I haven't heard from you since you set me a message on Facebook threatening to kill me, my wife, and two boys in our sleep because I corrected you regarding your delusions about what a 1075 is capable of.
I hope things have been going well for you and you enjoy walking while you still can. Hope to see you soon! :bestwishes:
Eliminated572 02-07-2017 08:52 AM
Appears his threats fell short. Just like his claims in the boating world... What a shocker :banned:
offshorexcursion 02-07-2017 09:06 AM
Troll or not, this thread was off to a bad start when it combined the words BRAVO and any number greater than 500
Speedracer29 02-08-2017 07:51 PM
Originally Posted by JRider (Post 4526493)
Darrish
I concur....
https://w2.lara.state.mi.us/VAL/License/Search
Not seeing a license for Scott Allan.
Wondering if "thewhitemongoose" can tell us where the FB cover photo was taken?
Griff 02-08-2017 09:32 PM
More Fake BS. A bunch of hood rats listed as friends but none of his posts have more than 2 likes.
It should be listed as psychiatric patient
Griff 02-08-2017 09:46 PM
More fake BS https://twitter.com/DrScottAllanMD/with_replies?lang=en
I guess he only has one pic of himself.
The president and founder of a foundation that does not exist and a ceo of company that does not exist.
JRider 02-08-2017 09:47 PM
WTF inspires these tools? I don't get it.
