-   -   bravo alignment tool plate / disc (https://www.offshoreonly.com/forums/drives-lower-units/344183-bravo-alignment-tool-plate-disc.html)
outonsafari 01-25-2017 10:27 AM
is there a an alignment plate / disc for the bravo similar to the trs ?
F-2 Speedy 01-25-2017 10:41 AM
http://www.ebay.com/itm/Mercruiser-A...vI8V5w&vxp=mtr
BUP 01-25-2017 01:54 PM
Mercruiser came out with a new slid on coupler to the alignment tool in 2007 that many do not know about period including dealers. Its used for alphas and another one used for bravos that helps with better alignment. You still need the Merc alignment tool when using the new coupler slipped on.
Its not what is posted in the ebay link above as those coupler tools are for installing gimbal bearing, and another one for installing U joint bellows and the third coupler is for installing the grease seal.
Also the Merc ITS Alignment tool works great for bravo non ITS apps as well I like that as well
F-2 Speedy 01-25-2017 02:46 PM
You can to use it for alignment, and installation, but then again I don't everything like u....GEEEEEEZZus
THIS IS FOR A NEW SET OF TOOLS: ALIGNMENT TOOL, GIMBAL BEARING DRIVER, SEAL DRIVER, BELLOW RING DRIVER, HINGE PIN TOOL, PLUS EYE BOLT.
AllDodge 01-25-2017 03:59 PM
Not sure but I think your asking about the plate tool 91-863372 which slides on the alignment bar and into the drive bell housing. This will show a gap if its not dead on aligned. You then can move the motor mount
https://drive.google.com/open?id=0B4...XpLUzZ5a0Nhek0
BUP 01-25-2017 04:01 PM
I know that for the long alignment bar only but he was asking about totally something else ie: the coupler I was talking about IMO. If not I was trying to give darn good added info on top of for whomever as I always try to do -- plus the info about the coupler what I think he was asking about or for whomever wants that info.
Now have to asking - why yell at me and the geeeezzus ? whats that about ?
BUP 01-25-2017 04:03 PM
^^^^^^^ BINGO as the tool I am talking about in my first post and that is the part number - I could not remember the part number nor had a pic. I posted this before about 2 years up here --- so maybe someone learned about it or not. .
BUP 01-25-2017 04:13 PM
Since I can not copy and paste from Merc I found this for whomever
http://www.mercstuff.com/alignmenttool.htm
good luck
AllDodge 01-25-2017 05:23 PM
Not to pick but the items in the Mercstuff link does not include the part I listed
outonsafari 01-25-2017 05:27 PM
thanks guys,
yes i'm looking for the disc that slides on the alignment tool and into the gimbal housing,
i have the shaft and disc for trs.
but i need the disc for bravo 1
edit in
https://drive.google.com/file/d/0B4y...Z5a0Nhek0/view
does the above slide over the shaft and into the bravo 1 gimbal housing ?
it looks like it does, if so thats what i need
