Bravo tools
Old 03-07-2017 | 07:56 PM
Default Bravo tools
Does anyone have a list of the specialty tools that are required to disassemble/assemble a bravo one drive? Not the more common tools like pullers, drivers etc that a good mechanic will have.
And yes I have a Bravo manual. Just wondering if someone had a list.
underpsi68 is offline
Old 03-07-2017 | 08:07 PM
Not a specific list but on eBay there's a member named whoya. He sells drive tools. Also an oso member.
Crude Intentions is offline
Old 03-07-2017 | 09:41 PM
The manual lists the tools needed in the various chapters, you just need to pick and choose the ones you need. The spanner wrench for the pinion nut on the upper( there's 1 for std bravo and 1 for X) the spanner for the lower retainer nut ( the one for the XR works on both) the race puller for the tower races, as I recall, it comes as a set with drivers for installing the races and clutch shaft bearings, the upper pinion height gauge, the lower pinion height gauge, the the dial indicator holder for checking upper gear backlash, the flags for the dial indicator to cantact, prop shaft seal driver and the plate that is used to set vertical shaft bearing preload are the things that come to mind...some stuff, I've fabbed up
JaayTeee is offline
Old 03-08-2017 | 09:13 PM
I have bought a few tools off whoya before.
Thank you both for the info, it is appreciated.
