-   -   Bellows Problem (https://www.offshoreonly.com/forums/drives-lower-units/348223-bellows-problem.html)
Scott Wierman 07-07-2017 11:42 AM
Bellows Problem
I have a bravo with drive oil bottle and my gimbal bearing came apart this spring. I limped back to dock but some of the housing is broken away. I replaced bearing and all joints. This was fine for about 25 hrs and the bellows came off. I cleaned and reinstalled bellows and 3 hrs later it is off again. I used extra bellows adhesive to hopefully help. But I guess not. Is there a fix for this without replacing the whole transom assembly? I just do not want to pull motor until end of season if possible. I am also looking for a good used assembly. Thanks in advance.
mrv8outboard 07-07-2017 01:03 PM
Did you use bellows cement? Pictures of the damage? I think there is someone who makes a temporary repair kit.
Scott Wierman 07-07-2017 01:18 PM
I did use mercury bellows adhesive. I was told that there is a temp repair kit out there but I am not having any luck finding it. I want to stop the water if possible. Especially because I run an extension box so I have 6 u joints and they are all new mercury joints not the cheap junk ones and they carry a hefty price tag
Bondo 07-07-2017 05:29 PM
Ayuh,..... Check out These guys,.... or get a new transom assembly,....
I've got a '90 Bravo transom, freshwater used,....
Scott Wierman 07-07-2017 10:01 PM
What is the price on your assembly? Is the swivel shaft tight? Where are you located? I'm in Wisconsin for shipping. Plz send pics to [email protected]. thanks
Bondo 07-10-2017 07:47 PM
Just found this tonight,... I'm in Chaumont Ny,.... Watertown,... Jefferson County,...
I'll get ya some answers to yer questions,.... Gotta dig it oughta the barn, 'n clean it up, check it out 'n see how tight it all is,...
I'll strip it down to what ya need, 'n weigh it,...
It's complete right now, as cut out from a hull with a demo-saw,... transom, 'n all,....
Bondo 07-11-2017 08:29 AM
Serial Number OB673161, it's a pre-oil bottle Bravo,....
Swivel pins appear to be nice, 'n tight,...
More info to come,....
