Volvo dpx drive power steering options >
Old 07-31-2017 | 10:27 PM
Default Volvo dpx drive power steering options
Hi guys, I have mechanical steering going into the hydrolic power steering ram on my 2002 Volvo dpx drive.
there is a rediculous amount of movement in the teleflex helm, heaps of play in the steering and my ram is leaking fluid!
i want to replace the lot but hoping for suggestion.
can I do something whereby I get rid of the Volvo power steering ram and have a separate aftermarket system?
The boat is a wooden donzi 16 replica.
really appreciate some good advice.
cheers
stu
Specializede5 is offline
Old 08-02-2017 | 10:34 AM
Ayuh,.... The most sensible up-grade would be goin' to a full hyd system,....
Hydraulic helm, 'n steerin' cylinder,... No motor mounted pump necessary,....
Bondo is offline
Old 08-05-2017 | 10:33 AM
scarabman's Avatar
If you really have a DPX drive, the external hydraulic steering cylinders are already mounted/being utilized? You have a Brasil Valve on standard power steering rack that is working the external side? If so, you only need a hydraulic helm, and to plumb the system.
scarabman is offline
