XR Gimbal Ring Replacement >
Old 04-11-2018 | 01:07 PM
Default XR Gimbal Ring Replacement
I'm restoring a 353 FasTech with 575 SCs. The gimbal ring of the STBD unit is cracked in half. Just got off the phone with Merc racing and they are telling me I need to pull the motor and remove the transom to replace the gimbal ring. Ouch. Anyone got a better idea for making this repair w/o pulling the motor?
Screechfighter is offline
Old 04-11-2018 | 02:38 PM
obnoxus's Avatar
Charter Member #1171
You can do it with a kit that drills holes in the transom plate to access the gimbal ring nut and then plugs the hole. Another one cuts out the back where the sticker is and then covers it with a plate.
Neither look spectacular when done. I would pull the motor. Also,,,, replace the steer shaft seal while you are in there. You have to go through all the same work to do it for a $23 seal
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-11-2018 | 02:49 PM
I have done the J&R Marine repair that drills where the sticker is located. It worked well and I did not have to remove the engine.
underpsi68 is offline
Old 04-11-2018 | 04:50 PM
Does the boat have extension boxes ?.... if so, you don’t have to pull the engine
JaayTeee is offline
Old 04-11-2018 | 04:57 PM
JR method
Instructions
I did the Merc method years ago and did ok
AllDodge is offline
Old 04-11-2018 | 08:58 PM
seafordguy's Avatar
If you're close to someone with a gantry crane it's only an hour or two to pull the motor.....
seafordguy is offline
Old 04-11-2018 | 09:11 PM
a 353 with Gil manifolds sucks to get at the motor mount bolts.
Unlimited jd is offline
Old 04-11-2018 | 09:57 PM
BUP
Have to say the JR kit, I have seen some leak over time. IMO I would check and reseal every so often. Its a good idea, the kit - but I also question cutting on a stock bravo transom assembly a good size rectangle piece if any of its integrity is compromise ?
And yes I have installed the kit as well.
BUP is offline
Old 04-11-2018 | 11:07 PM
Thanks for the input, fellas. I considered cutting the plate out but concerned about what it looks like after the repair and the Merc rep said the same thing as BUP--I'd be cutting out a hunk of metal on a high performance drive that I'd probably like to have. Just a kick in the teeth because I though I was in the last week of hard labor and have spine surgery in 11 days. I think I'm with Obnoxious, just get the motor out and do it right.
Old 04-12-2018 | 06:54 PM
I' be shocked if the thin piece that gets cut out with the Jr kit does anything.
