Changing rotation on SSM3 >
Old 04-12-2018 | 07:52 AM
Default Changing rotation on SSM3
I have 2 spare lower SSM #3 drives for my current boat. One is a LH with a bad case and good gears and one is RH with good everything. I actually need a good LH lower to replace one on my boat, so what do I need to change out of the RH to make it a LH?
I've rebuilt just about anything with gears and used to set up automotive gear cases all the time (Dana 60s, 44s etc). I am mechanically inclined and I'm just curious which gears get swapped over and how big of a job it is.
Any help is much appreciated,
Rambocj7 is offline
Old 04-19-2018 | 09:12 AM
the prop shaft and lower gears will need to be changed to change the rotation of the drive......this is minimum...there may be more.
I suggest you get a service manual for that outdrive....there are many special tools needed (or make them like I intend) to complete the job. The manuals are no longer in print....I got mine used off ebay.
SS496 is offline
Old 04-19-2018 | 02:27 PM
RMPRam's Avatar
If you decide to do the change I have new #3 LH and RH lower gear sets for the #3 drive as well as new BIG propshafts for both.
RMPRam is offline
Old 05-18-2018 | 03:50 PM
The SSM III & SSM IV use the same propshaft for either rotation. The LH is a 4 gear set & RH is 3 gear set. The RH propshaft gear has teeth on both sides. The IIIA & V drives use different propshafts for rotation. With the parts being as expensive as they are & the special tools required I would highly recommend not attempting this yourself.
SutphenL30 is offline
