Have engine and Bravos off, what should I check/replace while here? >
Old 05-31-2018 | 09:52 PM
Sydwayz's Avatar
Forum Regulator
Be sure to install new starters, new bilge bumps, and triple check anything on the bottom of the engines: bolts, nuts, connections, clamps, etc.
I had my AT for almost 14 years and never had to pull the engines. But one time I did find an oil pan bolt in the bilge, and it was a real bear to find where it came from, and reinstalling it was a 1/2 case of beer in itself..
Sydwayz is offline
Old 06-02-2018 | 09:31 AM
Get on eBay for the install and alighnment tools, a member here make them to merc spec and sells them on eBay
under the name whoya2350. The whole driver and alighnment to is $110
https://www.ebay.com/itm/Alignment-Tool-Gimbal-Bearing-Seal-Bellow-Tool-Set-Mercruiser-91-805475A1-OMC/282420031118?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m1438.l2649
You can also look up Frisco boater on youtube he has a good instructional video on changing the bellows and gimble bearing.
Mohavvalley is offline
Old 07-17-2018 | 10:42 PM
this is a must, your going to need this
this is a must..your going to need this
RBPOWER is offline
