-   -   IMCO Lower on a 24x7 hull? (https://www.offshoreonly.com/forums/drives-lower-units/354620-imco-lower-24x7-hull.html)
bogdan3031 06-13-2018 11:20 AM
Has anyone put on an imco lower on a Pantera, Superboat, Sunsation, Pyhton, etc 24x7 hull? I have some upgraded power (640hp bravo x upper, stock lower) on my Sunny and wondered about making it more efficient. Follow up question would be standard, -1, or -2? The lower is close to needing to be changed anyway and for the money/strength might as well go with the imco.
rws 06-19-2018 06:19 AM
Do you know what your X dimension is ?
I put a -2 Imco on my 24 Python.
The X is set at 18" but there is a 12 ext box.
Due to excessive slip at mid range i put a 1" spacer back in, also the Imco water pickup is easy to plug with weeds.
For boating in lake Erie i just run a standard length drive.
rws 06-19-2018 06:23 AM
As far as speed increase,i saw +4mph with -2 but not worth the expense due to water pressure spikes and weed issues, i had to install a presure relief valve.
bogdan3031 06-19-2018 08:57 PM
Thanks for the info on yours. My x dim is 15" but would be 18" except for its a sunsation and has a flatened hull at the back. Im not worried about weeds as im in northen lake mich not really a problem round here. From what im hearing though, might run into the same slip issue as you with the -1 due to the flattened hull.
phragle 06-19-2018 09:25 PM
Flattened hull at the back?? like a little delta pad?? If you truely are 15" measured from the outside pad bottom, you are really deep.... I (22x7 same basic hull ) just cut my X at 18" up from the pad.
