New xr getting hot >
New xr getting hot
New xr getting hot
Old 06-27-2018 | 09:51 AM
Default New xr getting hot
replaced my B2 X drives with the new B2 XR diesel drives. Changed ratio from 1.81 to 1.65 and dropped the props from 22 to 19s. Performance is about the same but I was getting 200 hours between changes on Neo oil. It would look like new when it came out. Now, the oil is black in the reservoir after 20 hrs. The paint is also showing signs of heat. Seems to be worse on the counter rotator. Do the xr gears run that much hotter? My dealer doesn’t have an answer and I don’t trust the drives.
offshorefisher is offline
Old 06-27-2018 | 10:54 AM
I think you might be over propped and this is causing the issue. I went from 2.0 to 1.81 (415HP to 539HP) and 24 to 22 and was barely able to get on plane with a B3 drive. Went back to my 2.0 and 26 pitch and runs great. In any case you need a drive shower
AllDodge is offline
Old 06-27-2018 | 11:30 AM
I have drive showers and if anything, I’m underpropped from where I was with the other drives. I’m about 2 knots or so slower than with the other drives that showed no signs of heat. Any other ideas? Thanks
Old 06-27-2018 | 12:20 PM
No clue hear, I have a new XR upper and its fine
AllDodge is offline
Old 06-27-2018 | 10:20 PM
I sent 47 pounds of failed XR upper gears to BUP on here, he had a gear guru analyze them and one thing that was noted was that they appeared to be getting hot....I’d suggest that you source an additional water source( off a trim tab or another hull pick up) route a hose to the upper and dump more water on them....even at that, don’t expect to get the life span out of these that you did out of the helical gears.
JaayTeee is offline
Old 06-28-2018 | 01:09 AM
That’s disappointing. I was told that the xr gears were much stronger and that the new diesel drive was built to handle torque. I’ve been getting 1000-1500 hours out of my Xes with 200 hr oil changes. My oil looks worse after 15 hours than it did after 200 in the xes.
Old 06-28-2018 | 12:36 PM
They are a bit stronger, they just don’t last as long before they start pitting and if you’re real unlucky, break off a tooth and break the case behind the pinion retainer nut....if this is your first oil change, what you might be seeing might be from break in, unlike the helical gears, these aren’t machined, they have a bit of a rough surface on the teeth that will wear as they break in, possibly this is what you’re seeing in the oil.... even at that, unless you never get on plane, I think your days of getting 1000-1500 hours out of a drive are over....I don’t think I’ve dealt with one that went much over 300 hrs.
JaayTeee is offline
Old 06-28-2018 | 12:51 PM
Heres a couple of pics, 1 shows the vaunted pits, the other shows the gear finish,
JaayTeee is offline
Old 06-28-2018 | 02:17 PM
F-2 Speedy's Avatar
what does the boat weigh with fuel and gear ?
F-2 Speedy is offline
Old 06-29-2018 | 07:37 AM
Possible they were set up incorrectly (lash or bearing preload too tight) and that is causing the extra heat? Everything else being equal as spur gear should run a bit cooler than a helical cut gear.
Perhaps it is just extra heat from the gears establishing a wear pattern......it is normal for a new set of gears to run hotter during break in.
Some temp data would help....but you dont have data from the old set up to compare.
I use temp indicator stickers on many things like this to see what the peak temps are.......they are cheap and effective.
https://www.mcmaster.com/#temperatur...ckers/=1dht73x
SS496 is offline
