TRS lower unit Gear HELP!!!!! >
Old 07-25-2018 | 11:07 AM
Default TRS lower unit Gear HELP!!!!!
Im trying to keep a old school offshore together. Im in need of one gear for the lower unit(the rebuilder has the other mating gear in stock). I need the vertical shaft gear the part number is 43-70934T1.
So far ive called Bam Marine(FL), Seaway Marine(WA), Drawbridge Marine(OH), North Bay Marine(MI), Mel Riggs(WI), CK performance(MI), Art Sommers(MI).
I know Ebay has as set of gears for $1000+ but trying not to have 4500 into a rebuild.
Im looking for that little hole in the wall pace with the one gear i need. HELP.
slpcamaross97 is offline
Old 07-25-2018 | 11:16 AM
J-Bonz's Avatar
Did you try Riggs Marine in Wisconsin?
J-Bonz is offline
Old 07-25-2018 | 01:59 PM
Yep he is the first guy i called.
Old 07-25-2018 | 10:09 PM
Mbam's Avatar
Offshoreonly Advertiser
These dealers all come up on the Mercury non-active parts lookup. I personally think they should make this public.
BOATERS WORLD MAR CT LAKE PLACID FL UNITED 863-465-6669
OFFSHORE PERF SPEC FORT MYERS FL 239-489-08841
DRAWBRIDGE MARINA PORT CLINTON OH 419-734-44220
DOUBLE R PERFORMANCE ON CANADA 705-487-7575
Mbam is offline
Old 08-31-2018 | 09:00 AM
I have two sets of Brand New TRS lower gears which I had Cryogenicaly frozen for more strength like NASCAR does for their transmissions and rotors!!! I will be excepting bids on these gears but please don't low ball them since even Bam has no pinion gears!!!
Franz is offline
Old 09-03-2018 | 07:29 PM
Default Jim
I have a complete trs lower
Jimj2 is offline
Old 09-03-2018 | 08:48 PM
Default Used Gears
I have 3 cases but no used lower gears,what are you looking to get for the lower unit and are the gears okay????
Franz is offline
Old 09-04-2018 | 05:20 AM
Are u interested in everything but case? Make me a offer
Jimj2 is offline
Old 09-04-2018 | 07:55 PM
Give me a price for the whole bottom or if the gears aren't pitted would you take $250.00 for them?????
Franz is offline
