Left handed prop on single engine❗️❗️❗️ >
Old 07-23-2019 | 09:44 PM
I have a max machine worx 2” thick billet top cap on my bravo xr with the larger mounting studs on my 713hp formula 271 spinning a left prop.
jwurl is offline
Old 07-24-2019 | 02:59 AM
Originally Posted by RDY2FLY
Thank for the info everyone, at this point I think I’m just going to sell the LH 28 and look for a right.
Run the LH prop, the boat was designed for it.
If it runs fine, why change? If it’s not broke, don’t fix it IMO.
I tested a RH prop on a single 29 and it would list to one side. I do know that the early 2000 low windshield style 27s came with a RH prop.
jtbooten is offline
Old 07-24-2019 | 12:17 PM
It’s has a 30rh on it now and that’s what it came with from the factory. I need less pitch when I loaded down with friends because it struggles to get on plane. My only concern is if I switch to a LH the stress will be in the other direction cause top cap issues or prop shaft stress. I don’t want to break anything when it can be prevented by getting a Rh 28 prop. I bought a LH not realizing it was a LH
RDY2FLY is offline
