Imco SC Rebuild
Old 05-01-2019 | 02:27 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Default Imco SC Rebuild
So on a scale of 1 to 10, how hard is it to rebuild(replace gears, seals)an Imco SC upper and lower? I have a pair that will be needing gears in both uppers and I am changing gears in the lowers to a different ratio. Looking to save some money but also educate myself.
fireboatpilot is offline
Old 05-02-2019 | 12:19 AM
Its the same as doing an XR. You need several specialty tools.
Griff is offline
Old 05-02-2019 | 06:53 AM
You will need to buy the manuals, tools, and I would highly suggest a drive work stand. All in, you are probably looking at $1600 for all the tools and stand. So long as you can follow directions and are patient, you can build your own drives.
endeavour32 is offline
Old 05-14-2019 | 08:35 PM
I recently upgraded my upper bravo 1 to XR with a 1:35, I was going to reuse the lower 1:65 until I eventually upgrade to an imco with same gear.But for now would the final gear ratio be ?
Bill0818 is offline
Old 05-14-2019 | 09:29 PM
Originally Posted by bill0818
i recently upgraded my upper bravo 1 to xr with a 1:35, i was going to reuse the lower 1:65 until i eventually upgrade to an imco with same gear.but for now would the final gear ratio be ?
1.5:1
JaayTeee is offline
Old 05-15-2019 | 01:25 AM
All XR upper gears are the same. The ratio in an XR is changed with the gears in the lower.
It may still come out as 1.5 as JT said(I don't know and he knows a ton more than me about XR's) but there is really no such thing as a 1.35 upper XR.
Griff is offline
