Bravo XR Spacer Question
I purchased a new boat, came with XR extension and pieces. studs etc. I cannot get a clear picture of what exactly I will need to install it. If i want new orings etc do i need to purchase. is the merc kit that i can buy.
It does have two orings in different sizes and the studs. Need help point his out to me.....Thank you.
You need 2 of each per drive when adding a spacer #3, 4, 5, and 18.
One set between the upper and the spacer and one set between the spacer and the lower.
https://bravoshop.net/schematics-bravo-xr-lower/
Thank you!
