-   -   Drive lost forward only (https://www.offshoreonly.com/forums/drives-lower-units/361626-drive-lost-forward-only.html)
Mickbat 07-05-2019 05:42 AM
Driving along about 4600 rpm not really pushing the boat and port motor hits rev limiter and lost forward but still has reverse bravo 1 drive. Checked cables and linkage all looked good Cone Clutch??? Any ideas thanks
JaayTeee 07-05-2019 07:02 AM
Is the drive apart?, l/h or r/h prop?
Mickbat 07-05-2019 07:05 AM
No she is still in the water will pull out today I wound up switching props to be able to use all the motors to get back figured what ever broke at that rpm has already trashed the insides drive that broke was RH rotation so took and switched outside drive props and ran them in reverse the boat has triples in it
JaayTeee 07-05-2019 07:32 AM
I had a driven gear crack between teeth and eventually break the cup off of the gear, might be that
Sydwayz 07-05-2019 11:00 AM
I had this happen once. It was a set screw that backed out; and travelled though the drive turning everything into apple sauce. I lost reverse, but I can’t remember which side/rotation. I thought it was a cable issue and ran it for the rest of the weekend.
I don't recommend running it at all.
Joe 07-05-2019 03:07 PM
Next time.... swap the props on the drives, put the boat in reverse and you're back to full power to get home before dark.
Sydwayz 07-05-2019 04:32 PM
He did, as posted above.
offthefront 07-10-2019 11:11 AM
https://cimg0.ibsrv.net/gimg/www.off...7dcc3f8711.jpg
More than Likely this is what you will find ..... got a whole box of em .....
Joe 07-10-2019 12:36 PM
You may want to talk to Matt at TNT... or, Brian Jackson at Offshore Outdrives.
If they're built and maintained properly, there's no need for that -ever.
endeavour32 07-11-2019 09:45 PM
I had the same issue with my boat on the 4th. No forward but reverse worked. it ended up being the upper thrust bearing had been completely chewed up! Which took out the upper gear, clutch shaft and all the bearings. Lucky for me, I had a new gearset, clutch shaft and bearings, and I wasn't only down a few days.
Have you torn into yours yet to see what the issue was?
