Outdrive Gear Lube Temperature Monitoring >
Old 08-09-2019, 07:24 AM
Originally Posted by Keith Atlanta
If you really want it, you could go all out and install cooling lines. Mr gadgets plumbed a cooling system on mine 7 years ago. Then the temp sender is inside the boat. That is good for a 40-50 degree difference in drive temps when run thru a cooler inside the boat.
I dont understand why more People dont do this , that has to help a Bravo last alot longer..
dunnitagain is offline
Old 08-09-2019, 07:41 AM
Its a combination of things, spraying oil in the right place, the oil goes thru a filter getting rid of particles and better cooling.
Its just a Tilton lube pump, some lines and fittings.
Keith Atlanta is offline
Old 08-09-2019, 10:22 AM
I know NEO oil is $85 a gallon, but it might be a cheaper solution. I can run 70-80mph with a full tank and 4 adults for miles and when I stop I check the drive temp and it's barely warm to the touch. I do have a good drive shower with a billet finned top cap.
ThisIsLivin is offline
Old 08-09-2019, 01:42 PM
I used mine to test a couple of different gear lubes. Amsoil runs about 30 deg cooler in my drive than Merc gear oil. My temp stays around 230 at a steady 70mph cruise.
snapmorgan is offline
Old 08-10-2019, 09:13 AM
Originally Posted by Griff
The biggest advantage I see is you get a baseline temp. If you notice temps getting hotter than what is normal, then you could prevent having a complete failure.
thats assuming the oil gets hot before a failure?
1MOSES1 is offline
Old 08-11-2019, 07:53 PM
are there external lines on the drive?
sutphen 30 is offline
Old 08-11-2019, 09:21 PM
Yes
Old 08-12-2019, 12:36 AM
BUP
I had some made a long while ago. What I found was once the sender went under water from coming off plane -- the temp drop a lot and fast so that told me if water hits the sensor the temp most likely is not accurate.. Also I did buy a few others to test. I tested with a cold water spray bottle at the sensor while running on the water hose ---- the temp dropped hugely very fast. Keep in mind I was only spraying the sensor and right at the vent hole.. Maybe this one had changed but I did have it as well years ago to test -- pic below just before I installed it. Did not pass the spray bottle either at that timeframe.
BUP is offline
Old 08-12-2019, 06:18 PM
that test tells me the sensing element in the TC is closer to the surface than the tip...if that’s the case, I agree you will never get an accurate reading.
1MOSES1 is offline
Old 08-12-2019, 09:45 PM
BUP
I am passing on what I have tested in the PAST.
If you ever took a temp from a running volvo SX or DP compared to Merc Bravo one or III - it is huge.
Bravo 3 is one hot son of gun
BUP is offline
