tilt
Old 08-21-2019 | 07:57 PM
Default tilt
If you can't get your drive up because of a bad switch or trim pump. Is there a way to manually bring a drive up?
Wharf Rat 1 is offline
Old 08-21-2019 | 08:51 PM
Take off one of the nuts off of the cylinder ram pin and pull out the pin, then you can lift the drive, then secure it with rope to a eyelet or a cleat
JaayTeee is offline
Old 08-22-2019 | 11:15 AM
Thanks. I will only have to take off one of the rams to do this?
Old 08-22-2019 | 12:32 PM
SB
Way easier with both off, which he referred too. Don't drive it with any rams off though.
SB is offline
