Merctrans with KC Shotgun cooler >
Old 10-28-2019 | 08:15 AM
cig28's Avatar
Originally Posted by seaman
is kc no longer in business. he did a tranny for me couple years ago with the gatling cooler and did a great job.i was gonna have him do another tranny for me for my carrera project. I've been running the lucas marine full synthetic atf that kc recommended with no issues. if he's no longer in business who else rebuilds the merc trannies.
Mel Riggs in Wisconsin, Nopper marine in Massachusetts.
cig28 is offline
Old 10-28-2019 | 07:29 PM
Originally Posted by phughes69
Are you able to find actual web pages on the Wayback website?
I did, and most of the tutorial info as well.
I'll post up a link when I get close to a desktop....rather a pain to do do it on the phone.
It's pretty funny...I'm trying to visualize the KC Marine cooler from description, so I can fab one up.
But I keep coming back to the concept of remote pump, cooler and reservoir.
Tartilla is offline
Old 10-30-2019 | 08:42 AM
My Merctrans was rebuilt by KC Marine. Was it their practice to up the pressure?
Rodger is offline
Old 11-05-2019 | 02:08 PM
I can have a look to see if KC Marine upped pressure as standard practice.
Though, if we treat the Merctrans as what it is, an automatic C6 Ford transmission, then all the same power adder tricks should apply.
Essentially, all the power from the engine is transmitted to the drive with the trans clutch pack and friction created from the pressure applied to the clutch plates. More pressure gives more friction, and more power holding capacity.
Tartilla is offline
Old 11-05-2019 | 02:14 PM
KC Marine Wayback links:
Home Page
https://web.archive.org/web/20170702...m/Default.aspx
MercTrans and TRS/TR
https://web.archive.org/web/20170619...ans-TRTRS.aspx
Merctrans Facts
https://web.archive.org/web/20170518...ans-Facts.aspx
Merctrans KC Marine Gatling Oil Cooler
https://web.archive.org/web/20170619...il-Cooler.aspx
Tartilla is offline
Old 11-05-2019 | 02:25 PM
The Merctrans should, at optimum, remain at 175 degrees or below, with 195 degrees being the maximum operable temperature.
There are some earlier copies of the website that has other good info.
Lower RPM operation is hard on the clutch, with lower pump pressure,vs. prop thrust resistance.
Lugging the Merctrans is also hard on it. Propping to the upper RPM for your engines needs, particularly important in the lower RPM operation, where pump pressure is low with a big prop to boat ratio.
No Photos of the Gatling Cooler that I could find.
My thoughts, are that a remote cooler, and pressure pump would be a good fir to this trans. It would also add fluid capacity.
Tartilla is offline
Old 11-05-2019 | 07:54 PM
Tartilla: Thanks for all the good information.
Rodger is offline
