XR VS SSM v or iv
Old 12-09-2019 | 12:29 PM
Default XR VS SSM v or iv
we are building a 35 motion with 2 525's was wondering which way would be the safer and most cost effective way for racing. i know the SSM's rob about 25% of power but i am told they are stronger but the XRS are easier to deal with as we dont need gear boxes. Just looking for some advice.
thanks
gorgs is offline
Old 12-09-2019 | 01:05 PM
Reliability is key in racing, I would say 6’s
Unlimited jd is offline
Old 12-09-2019 | 01:22 PM
unfortunately 6's are out of our budget.
gorgs is offline
Old 12-09-2019 | 01:35 PM
F-2 Speedy's Avatar
Are the 525's a spec class engine meaning stock ? or being modified
F-2 Speedy is offline
Old 12-09-2019 | 01:43 PM
they are going to be stock so 525 hp
gorgs is offline
Old 12-09-2019 | 02:02 PM
F-2 Speedy's Avatar
A well built XR with a steel tower and upgraded gears with an IMCO lower should work...........the Bravo shop or All American drive service
Old 12-09-2019 | 04:01 PM
In that case, go with xr’s. If you break a 4 or 5 you may not be able to fix it during the season.
Old 12-09-2019 | 07:53 PM
Once you go transmission you`ll never want a bravo drive ever again.
ICDEDPPL is offline
Old 12-09-2019 | 08:52 PM
if you are going to race I would not waste time on bravo's. when we ran supercat light we ran 525's and bravo's, we had to replace pinion gears every race and gimble rings every few races. that was all they would last running hard on a cat. most everyone went to 6's to avoid the failures, in the end the 6 was cheaper than constantly rebuilding bravo's. if you cant swing 6's then with that power a set of 4's or 5's would last all season with just oil changes. I have a set of 4's from a triple boat that only have 36 hours on them in the classifieds if you are interested in going that route.
compedgemarine is offline
Old 12-13-2019 | 09:15 AM
This
SS496 is offline
