-   -   Identifiy Bravo drive and lower unit (https://www.offshoreonly.com/forums/drives-lower-units/364319-identifiy-bravo-drive-lower-unit.html)
AllDodge 05-26-2020 08:42 AM
Note: The drive will probably go into gear easy enough, but it may not want to come back out without the drive rotating. If it takes to much of a pull, jump the solenoid again while pulling to neutral
JohanSweden 05-26-2020 09:08 AM
Originally Posted by F-2 Speedy (Post 4740733)
I dont think your 4th octet is a 9..........might be 203253 ?
If I search with 203253 I dont get any results, only when I put a 9 instead of 0.. :(
Im not that good at English, but I will try to understand what you mean :D
