Bravo 1 loose steering
The Imco add on works fine , Ive done several . Its a good addition to boats in your speed range .
Make sure the tiller arm cross bolt is tight and that the swivel pin nut is snugged down on the tiller arm.
Ive seen the bolt through the tiller broken , it lets the tiller square spread and makes it flop.
you don’t need the tiller arm connected to steering linkage with add-on ram. BUT you just need to make sure the nut on top of the swivel pin, up inside that plate on Gimbal housing, that sits on a washer on top of tiller arm is snug. The tiller arm still provides the spacing to tighten that swivel pin. You want to just make sure that is 100 percent.
but what be sitting in my mind still would be if the tiller arm is not busted. If someone put that plate on top of drive, I’m assuming they put a new stainless swival pin and seal. They should have put a newly conditioned gimbal ring and at that pt a new tiller arm, which they clearly did not. I’d want to make sure that arm is not busted.
Its the steering on a boat that goes relatively fast on rough water. Provided you do not like leaks that eat transoms, unintentional swimming lessons or yourself, family and friends getting injured or worse....If there is the least question in your mind, take everything apart, inspect it and repair/replace as needed.
Id say yes!
