Bravo One Alignment at Bell Housing >
Old 02-18-2020 | 08:53 PM
Default Bravo One Alignment at Bell Housing
With the double wound lock washer and fiber washer installed between the bell housing and transom plate the alignment tool hits about 1/4” low on the coupler. If I remove the felt washer and double wound lock washer it align much better. What would cause the engine to sit too high at the transom plate?
I had everything apart for transom repair so anything is possible.
When I took it apart I do not remember a double wound washer or felt washer. I bought those parts based on the parts diagram as I was putting it back together.
smcclay is offline
Old 02-18-2020 | 10:20 PM
Texascuda is offline
Old 02-18-2020 | 11:09 PM
Later models no longer use spring washer . Good luck.
PARASAIL941 is offline
Old 02-19-2020 | 05:48 AM
Did Mercury change the bell housing when they did away with the washer?
It’s possible that the bell housing is not the original since I bought this boat used.
smcclay is offline
Old 02-19-2020 | 06:27 AM
They changed the bushing. If the bushing has large serrations on the bottom it’s the new style
Unlimited jd is offline
Old 02-19-2020 | 06:28 AM
F-2 Speedy's Avatar
It has to do with the bushings that are pressed into the bell housing, as stated above the later ones don't use the spring
F-2 Speedy is offline
Old 02-20-2020 | 07:11 AM
I do lots of engine r&r. Just a tip remove the gimble bearing its easier to see which way to go. When you put bearing back in do a final check. If you put new rear mounts in i find they settle lower after a few days. Hope this was helpful
actionmarineguy is offline
Old 02-24-2020 | 09:04 AM
Default Double lock washer not needed
I pulled out the double wound lock washer and fiber spacer and the drive lines up. What hardware do I use to bolt it down? Do I use the same bolt, spacer and washer on top of the flywheel housing?
Here is a picture of the alignment before removing the lock washer and fiber washer. The back of the engine was sitting too high.
smcclay is offline
Old 02-24-2020 | 02:37 PM
1 MAIDEN AMERICA's Avatar
Rotate engine-if alignment changes-bad coupler
Does the block have dowel pins in it?
The gimble bearing will rock in transom assembly. Have you smacked it up, down and sideways?
1 MAIDEN AMERICA is offline
Old 02-24-2020 | 05:57 PM
I didn’t realized the gimble bearing could shift. I will check the items that you suggested and report back. I can lift the engine completely out this weekend and remove the flywheel cover. Should I have dowels in the back of the block? The flywheel housing has the holes to accommodate them.
smcclay is offline
