Bravo 1 top cap tork spec
Had some minor corrosion so took it off
any sealant that needs to be used or the oring get the job done alone? and how tight do we screw the cap in? https://cimg9.ibsrv.net/gimg/www.off...6ebdc65f0.jpeg https://cimg4.ibsrv.net/gimg/www.off...a267c7cb6.jpeg https://cimg7.ibsrv.net/gimg/www.off...57a71ffaa.jpeg |
Google says 20 ft-lbs...someone with a service manual can confirm.
Spec
The book States 20 lb
Need some polishing/smoothing on those surfaces where O-ring and seal surfaces
Before it goes back together, have you removed the back cap to inspect? |
20Ft Lbs and A Thin Layer of Perfect Seal to help with seal and Corrosion .
Originally Posted by AllDodge
(Post 4727650)
Originally Posted by dunnitagain
(Post 4727787)
Originally Posted by jeff32
(Post 4727909)
no i did not... nothing on the magnet when removed to drop oil so... should I really?
| All times are GMT -5. The time now is 08:58 AM. |
