Bell housing to inner transom plate washers
There were two dilapidated fiber washers (one each side) between the mounts on the inner transom plate and the mounts on the bell housing. How thick should the be? Can they be replaced with solid washer of same thickness?
Well, I ordered new ones and they were .200 thick. Put it together and bar hit bottom of coupler. Had to lift front of engine and inch and bump bar around to get it close. So I made aluminum pieces at .160 and put front of engine back down where it had been and with a few minor adjustments had it lined up.
Thanks for the assistance.
