Bravo 3 Oil Leak 1997 origin?
So when I fill it with one quart of drive oil, no leak. When I get to about a quart and a half then it starts to drip out of the prop hub. So thinking it is Not a prop shaft seal as that would leak all the way to empty. So where would it be leaking that is higher up? There is no oil coming out of the shift linkage area. None coming out of the water passage/pickup holes or anywhere else. It drips quickly out of the exhaust/prop hub. It will drip until about half a quart leaks out then it will stop. Then I can drain the remaining quart out of the drain hole. NO leaks at one quart, solid leak at a quart and a half. Any ideas? Thanks. 1997 Bravo 3.
It was not leaking and now it just started?
Would be the O ring seal
Need a serial number to ensure correct locations
https://www.mercruiserparts.com/bam/...30967/1943/220
Leak is in bearing carrier in lower unit where it sticks out aft of the main casing. Corrosion hole thru the side. Anyone ever change one of these? Tough?
part #
Threads into main casing.
Exploded view part # 39
https://www.mercruiserparts.com/bam/...30972/1943/250
Thanks for any input.....
part #
865876A01
https://www.mercruiserparts.com/8658...rrier-assy-brgThreads into main casing.
Sorry but misunderstood where it was leaking.
If its leaking around the outside of the carrier, then probably need a new case
The carrier needs a special tool to remove and it has right hand threads, so it is turn to the right (clockwise) to loosen/remove
Yes that is the piece that has corroded thru to the point of leaking. It is leaking right thru the side wall of that goldish colored piece about an inch aft of where the exhaust flows in. If I can get it loose, is it difficult to change or can a new one just be threaded in? Any sims/adjustments needed? Thanks
the new type seal
1 each Large outer seal 26-861694 (replaces 2 each lip seals)
Dimensions 3 - 3/8 OD, 2 - 1/2 ID, 13/16 wide
Need tool 91-805374
