Drive goes down not up >
Old 06-10-2020 | 03:30 PM
Default Drive goes down not up
Bravo xz drive power trim only works going down. I replaced 1 solenoid. Goes up if I reverse the big blue and big green wires on the solenoids . Power to the solenoids from the switches from the little blue and green wires. Very frustrating. Any help would be appreciated
toyboat991 is offline
Old 06-10-2020 | 04:23 PM
Probably need more info, but I'm thinking a bad switch Throttle or limit) or corrosion on the 3 prong connector
Does the trailer switch bring it up?
AllDodge is offline
Old 06-11-2020 | 07:45 AM
Wally's Avatar
Were doomed!
So you get power to the solenoids through the small green/blue wires.....does each solenoid click as you get that power signal? If not then check the ground on the solenoid on the one that's not clicking....if ground is good then replace solenoid.
If solenoid does click then check the output of the big blue wire (that's the one "usually" wired for UP position) or green if wired opposite....if there's no power output, then the contact inside the solenoid is bad and you need to replace the solenoid and you should be good to go.
If you do get a power output on the big colored wire then i would check the connector for corrosion...or there's a break in the wire going to the motor.
You can also bypass all the solenoids and test the pump itself by unhooking the green and blue motor wires from the solenoids and going straight to battery....you can keep the black ground wire hooked up assuming its got a good ground since the motor does work in one direction....then run a length of wire from the the battery positive and hit the green or the blue wire on the pump motor one at a time and it will trigger it to work. If it still doesn't go up then the wire connection going to the motor itself has a break somewhere...and you'll probably need a new motor or a new pump assembly depending on how you want to fix it.
-Wally
Wally is online now
Old 06-11-2020 | 07:58 AM
Active Streak: 30 Days
Check your connection at the 3 prong connector leading into the pump assembly. I just fixed a friend's drive last week that would not go down. I cannot edit the above picture, but the connection I am referring to is to the right of the Item marked "F". His had some corrosion and was not plugged all the way in. There was also some corrosion in the fuse holders around item "A". Be patient.
Helmwurst is offline
Old 09-23-2020 | 07:51 PM
Suspect any "push on" electrical wire connectors, especially any on a solenoid. Replace with "bolt and nut" type connectors to solenoids.
josephleecanton is offline
Old 09-26-2020 | 04:50 PM
obnoxus's Avatar
Charter Member #1171
As mentioned above,,,,Does it go up if you hit the " trailer " button? If yes, its the trim limit circuit, if not I would look at the solenoid. Also, do you hear a " click " from the pump assy when you hit the trim up switch? That would also point to a bad solenoid.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
