Bravo One XR stuck in forward - Help!
I took the drive off now.
No problem with the shift cable linkage or the jaws.
Tried to push the yoke up, but it still stuck.
Tried to take the drive shaft and spinn it with my hands and at the same time push the yoke up, but it still stuck..
Now what..?
Take every piece out of the drive?
Now what..?
Remove the socket head screws (item 13) on the shifter yoke and shifter linkage.
Find a screw which will screw down into the top of the shifter shaft (item 7). The screw will be used to pull the shaft out the top of the housing.
https://www.mercruiserparts.com/bam/...0990/10270/140
Not sure but the screws that are removed should be able to be used to pull shaft, thats how I pulled mine on a standard Bravo
Will try this tomorrow when back in garage and see how it goes! Will I be able to shift it back to neutral after that or is it more steps after?
Thank you again.
I have now removed the screws and the shaft.
And the shift yoke. It was a little notch on the shift yoke and the shaft.
With the shift yoke removed, I still cant move the clutch to neutral..
The p/n for the wrench is 862219A1, you need it to torque the pinion retainer nut when you put it back
together
a couple of othe things of note, the shift fork goes in with the nuts facing down and the gears have to be timed, there’s + and - on each eccentric ring on the gear, rotate the gears so the marks are at the centerline of the shift shaft bore in the case, match up - and + or visa versa, just don’t align the same 2 marks, then you install the pinion gear back in the case
together
JohanSweden (07-25-2020)
I wouldn't try to remove with just a pin wrench, the special tool is a joke IMO (bad design) but has several hardened pins which to hold about 3/4 around. Need to find someone that could loan it. I'm see where its going to get way involved and going to need more tools as it progresses
