Bravo one drive failed yesyerday >
Old 08-03-2020 | 08:42 AM
Do you run it in rough water?
Keith Atlanta is offline
Old 08-03-2020 | 02:54 PM
yea, but not rough enough to bring the prop out of the water
cloudmaster_321 is offline
Old 08-03-2020 | 03:26 PM
F-2 Speedy's Avatar
Originally Posted by Baja Rooster
I’m no brain surgeon, but that looks like the drive seized while the prop tried to continue spinning and wrapping that shaft into a knot.
I agree with this, especially with no damage to the prop, its just a 1 in shaft, id buy a good used B1 to save the season, and make the drive change later.......jmo
F-2 Speedy is offline
Old 08-03-2020 | 10:50 PM
Got the drive off today. She was stuck on good, the input shaft splines are twisted as well. No where as bad as the prop shaft though. I found that the u-joint bellow was full of drive oil. So now I know where my reservoir oil went. I pulled the top cap, and back cap, and upper gears are destroyed. Prop shaft is locked. The input shaft turns, but input gear is locked. So I don’t know if the shaft sheared the splines or gear is broke or what. But perhaps rubber coupler is ok then. I couldn’t see any real evidence the coupler spun. How do I test that?
Id be open to finding a cheap drive if I knew I didn’t need to pull the motor for a coupler replacement, as that would be a winter project. Is there a tool I can buy that would engage the coupler so I can try to spin it? I havnt found one searching online.
Old 08-05-2020 | 12:53 AM
Pull the drive shaft out if the destroyed unit. Use it to see if you can turn the coupler spline. Or use a mirror and look at it from inside. If it's torn you'll be able to see it.
Smitty275 is offline
Old 08-05-2020 | 03:54 AM
Theres your typical 200hr XR gear set. Huge fail on Mercury's end IMO. Hopefully your cases aren't damaged.
Drock78 is offline
Old 08-06-2020 | 07:40 PM
Wasn’t a XR. It was a Bravo with cyrogenic hardened gears.
Old 08-06-2020 | 08:07 PM
Gotcha. I misread it.
Drock78 is offline
Old 08-08-2020 | 04:46 PM
Call George at AADS. He rebuilt my drive after
I blew it up for less than a new one and gave me a 24 month warranty behind 700hp. 4 years later and it’s still mint.
ThisIsLivin is offline
Old 08-08-2020 | 05:24 PM
Ditto on All American Drive Service. Great people.
Padraig
Padraig is offline
