Mechanical Drive Trim indicator removal help >
Old 08-08-2020 | 07:02 PM
Default Mechanical Drive Trim indicator removal help
I remember something about installing a pin before removal to keep things from going into the drink. I need to remove the one on the port engine to access the hydraulic tilt lines. Any gotchas?
lear60man is offline
Old 08-08-2020 | 11:39 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
There is a small hole in the end of the SS sleeve of the indicator, and one in the black plunger/rod. It’s pretty easy to see.
Trim the drive all the way out, and push the plunger in with your hand. Insert a medium sized nail through the sleeve and aligned hole thru the plunger. Then release the plunger. The spring loaded plunger will hold the nail in there.
Sydwayz is offline
Old 08-09-2020 | 12:08 AM
Just trim drive up and remove the T clamps when the plunger is fully extended. The plunger is screwed to the morse cable and nothing will fall out.
A word of warning......The T clamps can gall the threads easily due to them being stainless. Put a little oil/grease on the threads when you reassemble.
Griff is offline
