-   -   Newbie changing drive oil...Bravo 1 (https://www.offshoreonly.com/forums/drives-lower-units/368238-newbie-changing-drive-oil-bravo-1-a.html)
F14A water jet 08-28-2020 09:31 AM
Originally Posted by AllDodge (Post 4754930)
If that is an original 1988 Bravo it will have a dipstick in the top cover. In 1989 the lube bottle was introduced
I will look...can you send a picture? Is this dipstick an accurate way to check oil level? Can I top it off through that?
F14A water jet 08-28-2020 09:48 AM
Where do I find "exactly" what units I have? They are hard to read but I believe my outdrives are:
Starboard - 0B899065 0B899965
Port - 0B899877
Drock78 08-28-2020 10:01 AM
Bam marine website should tell you
AllDodge 08-28-2020 10:03 AM
Those are the first serial number range
https://www.mercruiserparts.com/brav...-thru-0f729999
Look at the top cap for the dipstick (item 11). If its not there it may have been replaced
https://www.mercruiserparts.com/bam/...y/30966/952/70
cheech 08-28-2020 10:12 AM
Look at the top cap for the dipstick (item 17). If its not there it may have been replaced
Fixed
F14A water jet 08-28-2020 03:29 PM
Perfect...dip stick is intact on both...will monitor!
Thanks, job completed. I got a little oil can/pump to top it off...worked great!!!
https://www.acehardware.com/departme...l-cans/2136786
zz28zz 08-28-2020 04:01 PM
Do yourself a favor and buy or make a pressurized oil dispenser to fill drive from bottom. A lot of us use a plastic bug sprayer modified to connect to drive. Others have purchased dispensers especially for this purpose. You'll never have to worry abt introducing air again plus it's much easier, faster and cleaner.
