Bravo 3 reverse issues >
Old 09-19-2020 | 07:20 PM
So...is there a general age or number of hours where one can expect to have this issue?
bajaman is offline
Old 09-19-2020 | 08:25 PM
IMO
Probably not, it depends on how the drive is used, how much HP, and what lube
Have not heard where its a bad problem, just happens every so often
AllDodge is offline
Old 09-21-2020 | 12:46 PM
You can get the plastic gauge for shift cable adjustment from MerCruiser Tools and Supplies for the do-it-yourselfer really cheap. I keep it in my toolbox on the boat. They have improved the cable design, if you have an older drive, it may be worth getting a new cable. I was having similar problems and it was the cable.
ThisIsLivin is offline
Old 09-21-2020 | 08:39 PM
Thank you for the info. I looked and didn’t see a shift cable gauge tool. Do you know what it’s called? Thanks much.
widerholdt is offline
Old 09-22-2020 | 06:47 AM
The last couple of shift cables I've installed didn't need the tool because the cable was preadjusted 91-17262
AllDodge is offline
Old 09-22-2020 | 06:47 PM
Thank you
Old 09-29-2020 | 05:35 PM
Thank you sir.
