-   -   Please Help!! 1988 Bravo one Nose Cone (https://www.offshoreonly.com/forums/drives-lower-units/368830-please-help-1988-bravo-one-nose-cone.html)
MacNeeseCowboys73 10-06-2020 08:02 PM
I need a nose cone for a 1988 Bravo one lower unit. I'm have trouble finding one for the year. If I cant get one to match the year, will a newer nose cone fit with my older drive?? I found one online at Bob's Machine, but they stopped carrying them. Any info helps, Thanks guys!!
GPM 10-07-2020 06:52 PM
I believe Imco still makes one
Griff 10-08-2020 01:02 AM
Why do you think you need a nose cone?? What speeds are you running??
Apexwarrior 10-08-2020 06:16 AM
Unless you are north of 90mph, I don't think a nose cone will do anything. That said, my Fastech was a handful over 90 and after putting the nosecones on it felt a bit more stable. Also gained a little top end. It was worth it for my application.
ThisIsLivin 10-08-2020 11:55 AM
I used one from Hydro-Motive, worked good for me too.
JaayTeee 10-08-2020 05:47 PM
The pre 90. Bravo’s had a shorter strut and bullet and would blow out in the 70’s the 90 to current will go 100 .... I’m not a believer on them on the 90 ups, but the older one can take advantage of them if you’re running mid 70’s
MacNeeseCowboys73 10-31-2020 01:06 PM
I bought the boat with nose cones already installed, one broke off and I was going to put one back on rather than take off the other one.
I do agree that I probably don't need them. My boat is a 88' Scarab Panther with 454s, only seeing like 60mph.
Griff 11-01-2020 12:31 AM
I would just take the other one off and sand the drives smooth.
I have them on my boat and don't need them either for my speeds and that is what I would do. They were put on when the boat was much faster.
JBA 01-06-2021 10:04 PM
I should have one. 402 689 3690
hullofjustis 01-09-2021 10:59 AM
How many of you have actually tested let’s say a 60 mile an hour boat and then put a nose cone on it and found no result I’m just curious. I assume everybody’s going by hearsay because I’ve heard that as well. I have actually never tried it but making something more hydrodynamic I would think helps any boat
I actually have two Imco nose cones that I’ve never put on that I was going to put on when I raise the x dimensions with Imco three up boxes but then I found 2 inch Shorty cases
