-   -   The difference between low bump high bump gear (https://www.offshoreonly.com/forums/drives-lower-units/370035-difference-between-low-bump-high-bump-gear.html)
285ssi 01-15-2021 05:01 PM
hi everyone, i'm looking to know how to differentiate low bump from high bump gear someone could guide me on that thank you
JaayTeee 01-15-2021 07:53 PM
As I recall, the high bumps will have H on the eccentric ( bump ) ring
right near the + - markings. X and XR gears are high bumps, only std bravo’s
list it as being optional
Keith Atlanta 01-15-2021 08:15 PM
What is this you speak of?
In 15 years of having a performance boat with a bravo drive, I have never heard of such lunacy!
(...If "performance boat" and Bravo should be in the same sentence is a whole other topic.)
JaayTeee 01-15-2021 09:01 PM
It really doesn’t have anything to do with the gears, they just thread on to them
Mercury doesn’t even sell them separately, but others do
https://www.cpperformance.com/p-1682...hift-ring.aspx
Their primary function is to hammer ( by the cam action of the rotating ring)the shift fork and cone out of the driven gear, when shifting out of gear, they do to a lesser extent, help it shift into gear, there’s also a more robust shift link set up used with the high bumps due to the heavier load they experience
bajaman 01-16-2021 06:23 AM
lol...I too was like, "WTF?", but I didn't want to say anything...
285ssi 01-16-2021 06:53 AM
Keith Atlanta and bajaman, I may have misspoken in my question but look at this photo and read it carefully and you will see know from the quicksilver marine parts
https://cimg5.ibsrv.net/gimg/www.off...7736618a01.jpg
