-   -   Exhaust block off plate (https://www.offshoreonly.com/forums/drives-lower-units/370645-exhaust-block-off-plate.html)
38fountained 03-04-2021 09:19 AM
Exhaust block off plate, anybody come up with a good temporary fix for a leaking plate, given it’s limited access without an engine pull...
SB 03-04-2021 09:55 AM
Block it from your exhaust bellows side ? Do you have a bellows ? Does it connect to drive or open before drive ? I did this for a few Alphas. Just a pvc rubber cap on those. :) I have not had to look into it on a Bravo yet, so can’t help you with anything but an idea(s)
38fountained 03-04-2021 10:03 AM
I have a bravo and I believe it has more entices to block off, not 100% sure though...I like the rubber cap idea.
Wally 03-04-2021 10:31 AM
If you cant get a rubber cap on the exhaust tube inside the gimbal then the only other idea i cant think of without pulling the motor to fix it properly would be some expanding foam shot into the opening from the drive side....
38fountained 03-04-2021 11:31 AM
saw where one guy used the foam and it didn't work. I did the same with 5200 and it leaked too.
SB 03-04-2021 11:45 AM
I asked a few questions on my first post. Doh.
Do you have the following exhaust bellow tube from your trans assembly to almost back of drive ? If so, i know on the alpha the round part that attaches to transom assembly can have , i believe, 3” (or was it 2” lol) round pvc rubber cap in it’s place. This exhaust tube supposedly is gor all alpha’s and Bravo 1’s....so....???
https://cimg5.ibsrv.net/gimg/www.off...f0d27332e6.png
https://cimg6.ibsrv.net/gimg/www.off...1c72440233.png
38fountained 03-04-2021 01:37 PM
Bravo had the bellows a the way to the drive. I removed thinking it was not necessary.
SB 03-04-2021 03:07 PM
okay, that’s good it’s gone. Saved you labor now of removing it. Go see if you can get a rubber cap on where the bellow mounts on out side transom assembly.
38fountained 03-04-2021 03:49 PM
Will do, 3 inch you say???
SB 03-04-2021 04:04 PM
I believe so. It wasn’t 4”. A 2” fit on the Alpha drive inlet. I remember that lol. The boats are here, but wrapped for winter. We are driving our trucks and sleds on the lake right now, not boats. Lol
