Transom assembly rebuild >
Old 03-07-2021 | 09:21 PM
Rookie's Avatar
Default Transom assembly rebuild
I'm breaking down my transom assemblies to repaint. Does this bolt just screw out? I does not want to move. I haven't put too much heat to it. I have been getting water intrusion and I believe it's leaking up here. Is there seals that need to be replaced?
Rookie is offline
Old 03-07-2021 | 10:42 PM
There’s a nut on the opposite side of the arm,
if that is off, the bolt in the tiller arm should come out
of the arm.
You’re going to find the steer shaft rusted/ pitted and the
steering shaft seal and bushing needing replacement
JaayTeee is offline
Old 03-08-2021 | 06:37 AM
of the arm.
ditto. from the pic, that top steering pin looks like it’s toast. looks like a fun job!!!
1MOSES1 is offline
Old 03-08-2021 | 07:01 AM
Rookie's Avatar
of the arm.
The nut is off. I'll get the torch out.
Rookie is offline
Old 03-08-2021 | 07:20 AM
Rookie's Avatar
It appears the steering in pin is the same between the alpha and bravo.
MERCRUISER PART #'s 98230a1, 98230a 1, and 866718a01
Rookie is offline
Old 03-08-2021 | 10:26 AM
Several companies make a stainless pivot pin that's cheaper than the steel Merc one FYI. No more rust!
87MirageIntruder is offline
Old 03-08-2021 | 12:22 PM
Rookie's Avatar
I found those and good reviews for their rebuild kit. $129
Rookie is offline
Old 03-10-2021 | 07:11 AM
jr marine
1MOSES1 is offline
Old 03-10-2021 | 07:24 AM
Ditto on JR marine. Give him a call. Very helpful. Has stainless steering pin and everything you need to put together and stop the leak.
liberator221 is offline
Old 03-10-2021 | 07:54 AM
I did the JR marine fix and didn't have to remove the engine or transom assembly. Both of mine now have stainless steering pins and new seals. And now external hydro steering. The JR fix worked well for me, cheaper/easier than pulling the engine, and allows future repairs. I got tired of the play between a 20 year old steering cable + this (poor) design.
Instructions
SabrToothSqrl is offline
