Shimming TRS PropShaft Carrier >
Old 04-01-2021 | 10:31 AM
Default Shimming TRS PropShaft Carrier
I have 1976 TRS drives and I'm changing the prop-shaft seals and bearing. I have been reading that it's better to shim the carrier like the older drives rather than use the crush ring. I can not find any info on what shims or backing ring to use. Any ideas?
I worked on drives for 30 years and can 't ever remember not having the crush ring in them. Would shims from an Alpha work?
Thanks, Einar
viking60 is offline
Old 04-01-2021 | 07:04 PM
Rookie's Avatar
These?
https://www.mercruiserparts.com/bam/...y/31035/986/60
RH
https://www.ebay.com/itm/mercury-shi...-/153447168016
LH
https://www.ebay.com/itm/0650P7-NEW-...-/254479732998
Rookie is offline
Old 04-01-2021 | 08:18 PM
Thanks Rookie but no. Those go behind the bearing races. The ones I'm talking about go between the Carrier and the Housing. They would adjust how for the carrier goes into the Gear Housing. They would replace #22 in the list there.
Einar
viking60 is offline
Old 04-02-2021 | 04:27 PM
Mbam's Avatar
Offshoreonly Advertiser
I'm pretty sure that is the same shims as an early Bravo. The load ring is the same as the TRS.
https://www.mercruiserparts.com/bam/...y/30966/952/90
#30 but the solid stuff is NLA. Try Imco they might have something.
Mbam is offline
Old 04-02-2021 | 04:50 PM
Thank you Marc,
Your web site say's you have 1 trust ring in stock so I'll order that one and then try and find shims.
Appreciate the help.
Einar
viking60 is offline
Old 04-02-2021 | 05:09 PM
Marc,
Your web site say that the thrust ring and shims are both #30. I've ordered the thrust ring, by chance does that include the shims?
Thanks, Einar
viking60 is offline
Old 04-02-2021 | 06:29 PM
I'm not sure that's going to fit between the Carrier and the gear, RH.
viking60 is offline
