Bravo 3
Old 05-03-2021 | 02:14 PM
Thumbs up Bravo 3
I am new to working on boats. I recently bought a boat that needed a new out drive. It is a bravo 3 that needs to be fixed. I think someone has replaced this before. My question is can bravo outdrive upper and lower be swapped ? For instance using a Bravo 1 upper on a bravo 3 lower. And for some reason I think this outdrive is a 2.43 gear ratio in a small light boat with 24" props. It has a strong running 350. I am trying to get the drive prop combo to cruise at around 3000 rpm to 3500 rpm. Any information would be gr8.
ShaneA55 is offline
Old 05-03-2021 | 04:41 PM
Yes uppers and lowers can be swapped with limitations. The older drives can only do it with certain models. See pic
Also need to pay attention to the gear ratios
AllDodge is offline
Old 05-03-2021 | 05:54 PM
youll need a 1.65 bravo one upper
flat rate is offline
Old 05-03-2021 | 11:31 PM
On a small, light boat 24 pitch props and 2.43 gears doesn’t add up,
2:1 is a popular gear for a b3 and you’ll see them run 28 pitch props
on boats as you describe
If it has 24 pitch props, I’m guessing it has 1.81 final gearing
( 27/29 tooth count, the same as a 1.36 B1)
JaayTeee is offline
