Bravo 3 upper gears
Hi, I lost forward gear under way. I got the boat out too the rear cap off. Looks like it’s selecting forward gear but when I spin the prop, the brass ring and clutch spin but the toothed gear doesn’t. Does this mean I have broken the floor out the forward gear?
thanks
thanks
The bump ring attaches to the clutch cup portion of the gear, they move as one, if the clutch and bump ring are moving together and the gear isn’t, I’m guessing the clutch cup has sheared off of the driven gear.
I had that happen once, it was due to a crack between a drive gear tooth that went clear through the gear and would cause gear flex
This whole bit spins but the teeth stay still
