Alpha gen1 ratio
Old 05-26-2021 | 08:42 AM
Default Alpha gen1 ratio
Hello All,
I have to replace a outdrive for a friend its got a 1.8 ratio, I found the same drive but its got a 1.9 ratio. This boat has a 3.7L can I use the 1.9 ratio drive and buy a bigger prop?
Zinger is offline
Old 05-26-2021 | 01:14 PM
Don't remember seeing a Alpha 1 with a 1:90 ratio, have seen a 1:98, in any case it will work
Do make sure its not a Gen 2
AllDodge is offline
Old 05-26-2021 | 01:38 PM
As I recall, there was a 1.84( which was used with the 470) and a 1.98
which was used with the 120/140
JaayTeee is offline
Old 05-29-2021 | 03:30 PM
Originally Posted by Zinger
Hello All,
Sure,.... if you can find a prop with enough pitch,....
Bondo is offline
