Imco sc lower causing ventilation >
Old 05-30-2021 | 12:47 PM
Originally Posted by SUPERSTITIOUS
Curious to see how that works out for you
Post results. Hope it works for you.
Will.do. Should.have mid week, test on Friday if weather is good.
Pulse74 is offline
Old 05-30-2021 | 12:49 PM
F-2 Speedy's Avatar
what happened to your other thread about this issue
Did you try what I suggested in the other thread you must of deleted, to remove the stud and nut thats sticking down below the bottom of the drive and replace it with an allen head so its flush with the bottom,
F-2 Speedy is online now
Old 05-30-2021 | 12:54 PM
I didn't delete. But yes, I tried that. No difference. Called Brett@bblades, called Max, called Fred @imco. And the only person who had some positive input was Max. Fred was zero help, which pissed me off since I bought lower direct from imco. Spend $5k and get zero help with issues. Not cool.
Pulse74 is offline
Old 05-30-2021 | 01:11 PM
F-2 Speedy's Avatar
sent you a pm
Old 05-30-2021 | 01:14 PM
sent you a pm
Pulse74 is offline
Old 06-06-2021 | 03:58 PM
well, took it out today. Same issues. The 28 bravo ran good once I got it on a plane but it took forever to get on a plane. To the point where it almost didn’t want to. Tried turning to port, and that did make the prop bite but then as soon as it bit it seem to spin out again. Tried slowing down to let my wake push me over that worked OK but still took forever to get on plane. my last try is this Max machine works plate. If that doesn’t work I’m about done. Just go back to the XR lower. once on plane it seems to act pretty good I’m getting 50 miles an hour at 3900
Pulse74 is offline
Old 06-09-2021 | 06:19 PM
Well between changing stud to flush Allen head and adding the max machine batwing, all.is good again. Get on plane without tabs and runs like a champ.
Pulse74 is offline
Old 06-10-2021 | 08:53 PM
SB
Glad I could help.
You where nervous this wasn’t gonna’ fix the issue huh ? :wink
SB is offline
Old 08-30-2022 | 07:38 PM
I’m having the same issues with my boat… went from bravos to imco scx/sc and now I boat won’t plane. What fixed your issues?
Hadtohaveit is offline
Old 08-31-2022 | 11:23 AM
Max Machine Worx out of Havasu sells this cav plate. I haven't tried one myself.
87MirageIntruder is offline
