-   -   Bravo 1 roller bearing internal gear (https://www.offshoreonly.com/forums/drives-lower-units/374317-bravo-1-roller-bearing-internal-gear.html)
312fastec 12-25-2021 12:13 PM
hello everyone, I'm looking for a way a puller to remove the roller bearings from the inside of the gear or the c-clip without damaging it to clean it properly and put it back it collects a lot of **** below the c- clip and you bearing
all stuff will be appreciated thanks for your help
AllDodge 12-25-2021 01:01 PM
Which bearing?
https://www.mercruiserparts.com/brav...-thru-0w249999
JaayTeee 12-25-2021 03:12 PM
If you’re wanting to reuse them, you need something like this
https://cimg1.ibsrv.net/gimg/www.off...7dbb99601.jpeg
Mercury doesn’t sell this bearing, IMCO and Bravo shop do however
312fastec 12-25-2021 07:39 PM
yes thank you I buy them from imco when I change them I realized that a lot of debris was collected under the c-clip and between the floor of the gear and the bearing I am looking for a way to remove them without damaging them
253 12-26-2021 11:30 AM
Check the spacing between the needle bearing rollers with a thin flat screwdriver,,if there is much gap,,replace them with new bearings,, I have seen these so worn that the needle bearings actually come out of the casing ,,then bad things happen.
I have a special tool to remove them.
312fastec 12-26-2021 01:45 PM
yes I always check the needles, I am looking for a tool to remove them easy without breaking it to clean properly
phragle 12-26-2021 04:25 PM
Not sure which bearing, but if I was going thru the trouble of taking the drive apart and cleaning contaminated bearings, I would just replace them.....
I have found with boats, every time I try and save a dollar, it costs me 100......
