-   -   Bravo One gear lube? (https://www.offshoreonly.com/forums/drives-lower-units/375440-bravo-one-gear-lube.html)
Griff 04-16-2022 11:15 PM
Originally Posted by liberator221 (Post 4829198)
Go to wal-mart and buy the Quicksilver High Performance like SB posted. $10 a quart. Change it every season.
Yep...^^^^^^^^
1989mach1 04-17-2022 10:29 AM
https://cimg8.ibsrv.net/gimg/www.off...320d915637.jpg
I have been using this for years and holds up way better then the merc gear lube. Coms out like new at changes and dont smell burnt-out. I also had issues with the merc oil guming up in the bottles causing a low gear oil alarm to sound every now and then.
madbouyz 04-17-2022 04:30 PM
I switched to that a few years ago on a B3 . From the very first shift into gear I could hear a difference.
Shifting seems smoother and definitely quieter now as does outdrive whine when running .
I'm sure I read here somewhere a long time ago that there's something about this stuff that in the event of water ingress into the gearcase it keeps water way from bearings and gears.
Gimme Fuel 04-18-2022 10:07 AM
I've been running Valvoline synthetic 75-140W in my bravos for several years now, add one pint of Lucas Synthetic stabilizer per drive. Been doing a 2-3 season drain interval. They shift great, and being 900+ hour drives, getting ZERO iron mud or fuzz on magnets unlike with Merc lube.
