Differences between Bravo hp and standard gimbals >
Old 05-21-2022 | 09:59 AM
Default Differences between Bravo hp and standard gimbals
Can someone tell me the differences between the hp and standard gimbal assembly and what to look for when purchasing one? Used pair on Facebook, seller is Paul Lasassa Sr. I have a 28 Cigarette needing a restore. Several have suggested a single big block with XR upper and Imco -2 lower in lieu of twin outboards or twin small blocks. Boat currently no power but was twin small block with bravo's. If I go the single big block, I assume best to get the hp gimbal. New to i/o, not boating.
Any help in what I should look for on an examination is appreciated. I see one of his gimbals is missing a bolt so I definitely will check to see if housing damaged, Thanks.
Looking is offline
Old 05-21-2022 | 10:16 AM
F-2 Speedy's Avatar
I think the HP of a single engine would dictate which one you would install if you go that way
Difference between an HP transom assembly and a Std Bravo
F-2 Speedy is offline
Old 05-21-2022 | 10:33 AM
Thanks Speedy.
Looking is offline
Old 05-21-2022 | 12:23 PM
F-2 Speedy's Avatar
Looking, do you know of any other 28's for sale, Id like to fine a solid hull and put my power in it........thanks
Old 05-21-2022 | 07:25 PM
bigboat28's Avatar
Do your research on the seller
bigboat28 is offline
Old 07-17-2022 | 09:49 PM
Speedy, Sorry, I do not. May sell mine if you are interested. PM me. Thanks
Looking is offline
